nucleo-F746 ethrnet, lwip configıration
2023-09-27 11:39 PM
I am using Nucleo F746 eval board. I configured ethernet and lwip. But I can't get ping. "Reply from 169.254.255.144: Destination host unreachable." I get feedback like: My ETH and Lwip configurations are below. Can you help with this issue?
STM32F7 Series
2023-09-27 11:44 PM
2023-09-28 12:00 AM
There is no ios file in the example in this link and I think I made a mistake here. How can I find the ioc file?
2023-09-28 12:09 AM
Open the project in CubeIDE and then in the main.c compare the configuration in this project to your configurations.
Best regards.
II
2023-09-28 02:41 AM - edited 2023-09-28 02:50 AM
Hello @HS ,
The STM32F746xx devices are based on the high-performance ARM®Cortex®-M7, for that it is recommended to configure cortex-M7:
- Enable ICache and DCache.
- Enable memory protection unit (MPU) in “Background Region Privileged access only + MPU Disabled ...” mode. Configure regions according to the picture below:
Could you please check the MPU configuration?
Kaouthar
2023-09-28 04:04 AM
Unless he knows about cache handling, I'd say that turning OFF the caches would be the easier path for a start.
2023-11-23 08:42 PM
I use F746_Discovery, i follow your recomendation about MPU and LDCache, and the configuration before about LwIP. In the main.c i have added:
extern struct netif gnetif;
while(1)
{ ethernetif_input(&gnetif);
sys_check_timeouts();
In the pc i made ping 192.168.000.123 but no have answer of the F746, some can lack here ?
I also ran the program LwIP_HTTP_Server_Netconn_RTOS and yes work, can see the ping, the http web
and LCD
2023-11-27 01:03 AM
At least you have the example working, then go through that code and compare to your own.
You'll learn a lot about lwip...
2023-11-28 10:33 AM
i see the example LwIP_HTTP_Server_Netconn_RTOS the call LwIP are mixed with lcd and os function, i search some simple for start of CubeMX or .ioc, because these is the purpose of these graphical configuration, make simple the management of the pheriperal.
