LEDs of Nucleo-STM32G070 does not light on at power on
Chao
Hi All
Just bought a Nucleo-STM32G070 board and I am new to STM32 MCUs, I tried to power the board with a micro USB cable that I used to charge my mouse after I have installed the USB driver (stsw-link009), but the LEDs do not light on as shown in the introduction video. I did not remove or add any jumpers, did not make any change on the board.
Anybody knows where the problem is?
Chao
Well, the LEDs indicate comms activity with the ST-Link - and there won't be any comms if it's just a charging cable.
4 REPLIES 4
Andrew Neil
Evangelist II
Are you sure that's a full USB cable - not just a charging cable?
Have you tried a different cable - one that you know gives a full data connection?
Hi Andrew,
It is just a charging cable I think, as it came with my mouse. Do you mean I need a FULL usb cable? I will try one.
thanks
Chao
bought a usb cable and the lights are on (LD1 stays red, LD3 stays green, and LD4 blinking green and off)
thank you Andrew.
