2020-05-15 02:35 PM
I see the manual for STLINK-V3SET refers to B-STLINK-VOLT as an orderable part that does the level shifting from 1.8V to 3.3V. However, I cannot find this part available at any distributor (Mouser, DigiKey, etc.). Am I missing something? Can someone help explain how I can do debugging on this chip when operating at 1.8V? I've never had any issues in past when using chips at 3.3V.
2020-05-15 02:43 PM
You need level translating buffers. For SWD things get complicated as SWDIO is bidirectional. B-STLINK-VOLT may be mentioned by ST, but it seems not available. Look how other debuggers do the translation, e.g. the Bl*ckm*g*c debug probe.
2020-05-16 01:00 AM
Hi.
Look at NUCLEO-L433RC-P development board. It has switch for 1.8V and 3.3V operation, and debugger is SWD with somekind bidir level shifter .
2020-05-18 09:58 AM
This is helpful. Thank you!
