Hi everyone, I got a new ST-V3 Link debugger, when I connected to my PC it says ST-LINK error (DEV_CONNECT_ERR). I tried in Cube Programmer. I tried upgrading firmware and when I connected to my PC i'm getting FAIL.txt file
PRASAD
@0693W000001tKeAQAU.png0693W000001tKgfQAE.pngIn the FAIL.txt file it says (The interface firmware FAILED to reset/halt the target MCU). Need help @Community member​  thanks
Imen Ezzine
Hi PRASAD,
Can you provide more informations, like what is the type of STM32MCU device you are using or what version of Cube Programmer?
Thank you,
Imen
I encountered similar problem, even the STLINK V3SET serial number is not listed under STM32CubeProgrammer or STLINK UTILITY and I totally cannot establish connection as well, my link is below, I received this new ST-LINK V3SET device three days ago:
https://community.st.com/s/question/0D53W00000aopjaSAA/the-stlink-v3set-cannot-establish-firmware-upgrade-via-stm32cubeprogrammer-and-cannot-be-detected-under-stm32cubeprogrammer-combo-list-under-device-manager-after-populate-button-is-clicked-it-is-0mb-and-hangs-please-advise
