2021-11-04 6:18 AM
But What It's mean exactely ? I must buy a Debugger like ST-LINK/V2 ? Thank you for your helps.
2021-11-04 6:41 AM
No, no need to buy more stuff. Nucleo boards come with an on-board ST-LINK chip. For SW Development use STMCubeIDE.
Here are some resources;:
hth
KnarfB
2021-11-04 6:41 AM
hth
KnarfB
2021-11-04 6:59 AM
Hi KnarfB,
Thank you for your helps, I'll look at your links....
2022-05-09 1:24 AM
I come back again. Now I have a evaluation board STM32L552, after the DS I must install the driver. Fo you know how I can find this driver please ? I installed on my PC only the STM32CubeMX only for this moment.
After to connect directely USB, I think the driver detection is correct :
But now the next step is How to work with this Evaluation Board ?
2022-05-10 1:49 PM
The answer is exactly the same as for Nucleo and Discovery boards! The driver is the same for all implementations of ST-LINK:
