2014-01-23 2:23 AM
I'm trying to achieve the maximum reading range from my demoboard CR95HF-A with a ISO 15693 tag (LRi2K). Until now I've obtained best results with modulation-index 10% and gain 34dB by writing 0x50 to ARC_B register: only 5 cm. Can I improve this result? How Can I increse the antenna current? Thanks in advance. #range #lri2k #lri2k #lri2k #lri2k #lri2k #demo-cr95hf-a #cr95hf-firmware #cr95hfSolved! Go to Solution.
2014-03-04 8:34 AM
http://www.st.com/web/en/catalog/tools/FM116/SC1444/PF253360
# and then in tab ''tools & software'' Have a nice day, ST NFC/RFID Dynamic tag e2e support2014-01-23 5:35 AM
Hi Andrea,
Thanks for the interest in our line of product, In order to help you further, I have a bundle of questions, sorry about that, - What is the size of your tag? - Is the reader : DEMO-CR95HF-AMB1054A ?
- What is the answer to IDN ? Thanks, ST NFC/RFID Dynamic supportHi,
I'm trying to achieve the maximum reading range from my demoboard CR95HF-A with a ISO 15693 tag (LRi2K). Until now I've obtained best results with modulation-index 10% and gain 34dB by writing 0x50 to ARC_B register: only 5 cm. Can I improve this result? How Can I increse the antenna current? Thanks in advance.2014-01-24 12:26 AM
First of all, thank you for your quick reply.
These are the answers: - What is the size of your tag? I'm using ahttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00092187.pdf
2x3 mm2 inside a card: it came with the demoboard. - Is the reader : DEMO-CR95HF-A MB1054A ? - What is the answer to IDN ? NFC FS2JAST02014-01-24 7:22 AM
What is the size of the tag's antenna? (sorry my question was confusing)
You have an old eval board, I suggest you to get a M24LR-discovery. Several options are possible :
1. buy it form distributors2. You can request it to your ST 's sales.
If you want you can contact me through moderator 's case of this forum. Or let me your email.
2014-01-27 5:27 AM
The tag is inside a card: I don't know the real antenna size.
Which antenna size is recommended to achieve the best range with my demo board?2014-01-28 12:18 AM
2014-01-28 2:39 AM
2014-01-28 6:58 AM
2014-01-29 2:45 AM
2014-02-11 3:42 AM
I've ordered the new Demoboard: I'll try my tests with this new hardware.
