WyeVs Delta
Options
‎2003-02-02 8:10 PM
Options
‎2011-05-17 1:16 AM
Posted on May 17, 2011 at 10:16
What if any software changes are necessary when changing from a wye connected motor to a delta connected BLDC motor when using the ST72141 processor in sensorless mode?
Options
‎2011-05-17 1:16 AM
No changes are needed in the software between a star and delta connections. Only the delay coefficient (which determines the delay between the back-emf zero-crossing detection and the next commutation) needs to be updated. Best Regards
