morgan2
PC and Emulator connection problems
  • January 31, 2003
  • 676 views
Posted on January 31, 2003 at 12:29
morgan2
morgan2Author
Posted on May 17, 2011 at 10:16
Hi
Sometimes the system works well. ( ST72141 )
But sometimes the Emulator : ST7 HDS2 Emulator (ST7MDT5-EMU2B) Could not link to PC:
We modified the compatible Parallel Port Modes. But it doesn’t working well
The error messages when started to debugging were shown as follow…
Starting debug session...
-> Emulator reset (LPT1)...
** Connection error (LPT1): gdi-error in hds: communication error with emulator board
-> Failed to connect target.
How can we solve the problem !!
Help Me Please!!
pjprv1
I have the same problem. It seems to be caused by a shutdown/turnon sequence between the emulator and software. I usually turn everthing off then back on and then it starts working again.
