Why max Voltage 50V on IHM03A1 development board?
2019-12-10 4:51 AM
The recommended voltage range is 85 volts which is also the same as the recommended voltage for the POWERSTEP01 device.
Motor Control Hardware
2021-01-12 2:19 AM
Hi @dungeonlords789,
the STM32 Nucleo Expansion boards for safety reason is limited to max 50 V of power supply.
2021-01-06 10:21 AM
The same question
@Cristiana SCARAMEL
2021-01-06 10:35 AM
Maybe security issues? Higher voltages need protection from touching.
2021-01-12 2:19 AM
