2019-04-18 01:04 AM
TwisterSIM becomes unstable after second simulation. Plotter interface hangs and becomes unusable... Got to close whole program and start again. (Win7)
Anyone knowing about that trouble ? Workaround ?
Thank you.
2019-05-02 05:15 AM
+1 up.
No one got this trouble ?
2019-05-03 06:09 AM
Hello Jeanpierre, probably the issue is due to an huge amount of data involved in that specific simulation. If the step size is small (~0.1us or less) and/or the parameter "write data every" is low, simulation lasting seconds requires a lot of memory. In this case is often enough to wait that simulation is completed.
