2025-03-24 3:14 AM
Register 6Fh, D[1] SPI_HSoff_high
Low ohmic path switch off disable bit for HS pre-driver stage A and B
0 / R/W (default) (‘1’ = low ohmic path enabled)
When D[1] =0, Low ohmic path between HS driver GHy_x and SHy_x is connected or disconnected?
When H-bridge output to driver motor running, should Low ohmic path be connected?
Thanks!
2025-03-27 8:22 AM
Hi @haihun
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Regards,
Billy
