2019-07-23 07:18 AM
We are to evaluating the L9916 (Multifunction alternator voltage regulator...). From the datasheet I learned that there are OTP registers which are programmed by I2C – as described in section “OTP Programming�? on page 30. Okay, but in addition we need a list of the registers and possible values, information which is not included in the datasheet. Please help.
NOTE: This question and answer originated from a customer support case which was handled by us. We regularly review support cases and add any helpful ones here for all to benefit from.
2019-07-23 07:21 AM
For programming the OTP registers please refer to attached application note.
2019-07-23 07:21 AM
