‎2022-11-28 08:24 AM
Hi!
I am looking for a brushed DC-motor ±12V controller for higher currents, typically 25A-30A. I have checked the ST products Evaluation & Development Boards for Brushed Motors - STMicroelectronics but it seems the highest current available is 2.5 A. However, it does not need to be a complete dev board.
I am considering to design something similar to Sabertooth 2x32 regenerative dual motor driver (dimensionengineering.com) that I can control with PWM from a STM32 MCU.
Any hints?
Thanks in advance
‎2022-11-30 01:44 AM
Hi @Lars Sörqvist,
for hig​h-current motor I can suggest a solution with Gate drivers + external MOSFET.
If you want evaluate our gate driver in a single board I can suggest:
Let me know if this info is useful to you, if yes please "Select as Best" label to close the topic.
‎2022-11-28 10:53 AM
Chinese IBT_2 board will do, but it's not ST. :(
‎2022-11-29 08:24 AM
Thanks, and yes, regrattably it is not ST :expressionless_face:
However, you pointed me in the right direction. Even though the BTS7960 chip from Infineon on the IBT-2 board is outdated, Infineon seems to have other chips and now I am considering this board:
BLDCSHIELDIFX007TTOBO1 Infineon Technologies | Mouser Sweden
Hi @Lars Sörqvist,
