2020-09-30 10:13 AM
The Nucleo f429zi comes with a set of arduino avalaible pins compatible with the x-nucleo-ihm04a1 physical connections, but I´m not sure if regarding software it´s able to get a link between them. Can anyone help me?
2020-10-01 12:52 AM
Yes, of course you can use them together.
But you need to adapt the software to your NUCLEO, the source code is currently provided for NUCLEO-F401RE, NUCLEO-L053R8 and NUCLEO-F334R8.
Good luck!
/Peter
2020-10-01 12:52 AM
Good luck!
/Peter
2020-10-03 7:38 AM
Peter, thank you so much.
