Handling of unused pins of STWLC38
Ryoma
I'm currently considering using STWLC38.
I have a question about connecting unused pins.
How should unused pins be handled?
(GPIO, SCL, SDA, INTB, VS, etc.)
Ryoma
4 REPLIES 4
willzhou
Hi Ryoma
 for unused pins i suggest floating, SCL/SDA is used for MCU/AP control or external to updated fw. If SCL/SDA is not used, i strongly suggest you set SDA/SCL pin as test point in the pcb for future update fw.
Hi willzhou,
Thank you for your prompt response.
I'll set SDA/SCL pin as test point as you suggested.
Let me check again.
May I also OPEN the VS pin?
Currently, only Rx mode will be used.
Vs pin can be open, you can refer to our small board
Hi willzhou,
Thank you for your response.
I now understand how to handle unused pins.
Ryoma
