2024-07-02 9:28 PM - edited 2024-07-02 9:29 PM
I'm currently considering using STWLC38.
I have a question about connecting unused pins.
How should unused pins be handled?
(GPIO, SCL, SDA, INTB, VS, etc.)
Ryoma
2024-07-02 11:04 PM
Vs pin can be open, you can refer to our small board
2024-07-02 10:44 PM
Hi Ryoma
for unused pins i suggest floating, SCL/SDA is used for MCU/AP control or external to updated fw. If SCL/SDA is not used, i strongly suggest you set SDA/SCL pin as test point in the pcb for future update fw.
2024-07-02 10:55 PM
Hi willzhou,
Thank you for your prompt response.
I'll set SDA/SCL pin as test point as you suggested.
Let me check again.
May I also OPEN the VS pin?
Currently, only Rx mode will be used.
2024-07-02 11:04 PM
2024-07-05 2:43 AM
Hi willzhou,
Thank you for your response.
I now understand how to handle unused pins.:smiling_face_with_smiling_eyes:
Ryoma
