2024-12-18 9:25 PM
Due to my mistake, when using the GUI tool to update the firmware, I mistakenly loaded the configuration file into both the PATCH and CONFIG sections. As a result, the chip is not functioning properly and cannot connect to the GUI tool. Is there any way to recover and reconnect to the GUI tool and update the firmware again?
2024-12-19 7:31 PM
Hi
please use this tool
If your wlc chip i2c is ok but GUI can not connected, please use wlc_ft260_Recovery tool, check attach file "wlc_ft260_Recovery.7z"
Wireless Charging solution Wiki - STMicroelectronics Community
2024-12-19 7:31 PM
Hi
