watch dog
‎2004-05-25 4:54 PM
‎2011-05-17 3:00 AM
ben, the WD is enabled at bootup, all you need to do is keep feeding WDRST, to disable the WD then you need to concern yourself with WDKEY.
Stephen[ This message was edited by: sabbot on 14-05-2004 10:06 ]- Mark as New
‎2011-05-17 3:00 AM
I thought all need to do to enable the watchdog timer is WDKEY = 0. if I don't reset WDRST periodically then will result in a reset of system. But an experiment has showed this way doesn't work. Can anybody tell me why?
‎2011-05-17 3:00 AM
Ben007,
The watchdog timer in the uPSD32xx works well. Have you been able to resolve your issue? If not, please contact us at:mailto:apps.psd@st.com
. Please include the following information: Name Company Name Phone Number Location (City, State, Country) uPSD part number of device being used (3234, 3254, etc.) Application Projected annual volume (units) Regards, uPSD Applications Engineering [ This message was edited by: uPSD on 18-05-2004 07:20 ]- Mark as New
‎2011-05-17 3:00 AM
I've figured out the watchdog problem using the trick posted early in this forum. It never works if follow the way stated by ST datasheet.
‎2011-05-17 3:00 AM
Could you tell us what that ''trick'' is? Is the watchdog reset by accessing PCON?
