ST7LITE0 programmer
‎2003-03-27 4:03 AM
‎2002-09-05 11:35 PM
''ST7LITE0 programmer HARDWARE + SOFTWARE..''
Hello! I would like to have a ST7LITE0 programmer HARDWARE + SOFTWARE.. but a cheap one!! I already used PIC16F84 and AT90S1200.. I program with PonyProg.. Can anyone tell me If there are any cheap programer for this one microcontrolor?!? Thank you. Jorge- Mark as New
‎2002-09-16 4:47 AM
Hello Jorge,
Softec Microsystems (www.softecmicro.com) make a great low-cost programmer for the ST7FliteO and other members of the ST7F family. I've attached the document that describes it. You can buy it on-line from them. I haven't found anywhere to buy the devices on-line as I believe they are not scheduled for production until October 2 I normally buy my ST7 devices from Anglia Components (www.angliac.com) as they keep a good stock. Let me know how you get on with your project. Regards Colin ________________ Attachments : undersea.jpg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzur&d=%2Fa%2F0X0000000bU2%2Fu1JyviEmw.gHfX6ERxiXopP4mRcZA9gtg10jMskSdHg&asPdf=false- Mark as New
‎2002-09-17 9:40 PM
Jorge,
I noticed that I forgot to attach the file of the Softec brochure Regards Colin ________________ Attachments : indart_flite0.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I08C&d=%2Fa%2F0X0000000bU3%2Fb5LqW5fInz0eyDrQcHUMPu8.Ztw9IIhc3Lj5sOD.ApE&asPdf=false- Mark as New
‎2002-09-23 5:02 AM
If you also look at Softec's website there is an appnote describing how to design your own ST7lite programmer. Also attached
________________ Attachments : indartfliteappnote.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzE6&d=%2Fa%2F0X0000000bTz%2FrsAm1Qmk2tLBEkqZAZGmpn_2IMsRtPYgwqeQhQXl._c&asPdf=false- Mark as New
‎2002-10-03 12:19 PM
If you plan to design your own programmer, have look at the ICC programing manual too, lot of data in there.
http://www.stmcu.com/modules.php?name=mcu&file=familiesdocs&FAM=15#Programming Manual
‎2002-10-16 2:46 AM
If you are only looking at programming ST has just released the STICK that will fit your needs at the lowest possible cost.
‎2002-11-05 7:57 PM
If you are looking of a good professional ISP programmer/debugger see at SofTec Microsystems web site (www.softecmicro.com). The product code is inDART-ST7F/D and it comunicates with the host via USB.
Regards,- Mark as New
‎2003-03-27 12:19 AM
Take a look at www.spen-soft.co.uk where you can download a fully functional ST7 programmer (with schematics & source-code), it works in standalone mode (keyfob) or connected to a pc via RS232.
Regards Spen- Mark as New
‎2003-03-27 4:03 AM
Actually, SofTec Microsystems actually sells two in-circuit debuggers/programmers for LITE0:
http://www.softecmicro.com/products.html?type=detail&title=inDART-STX/D
(debugger/programmer unit alone) andhttp://www.softecmicro.com/products.html?type=detail&title=inDART-STX/LITE0
(debugger/programmer unit + LITE0 EVA board). Additionally, on the you can win a free inDART tool by contributing with interesting posts. Hope this helps, Paolo
