2007-02-13 8:19 PM
2011-05-17 12:36 AM
I notice this is used on the STR91x EVAL board. Is it OK for new designs or likely to become obsolete in the near future ?
Can you recommend an alternative MII PHY device please. Thanks.2011-05-17 12:36 AM
Hello fellow STR91x users.
I've had a look at various STR91x and other evaluation boards and here is what they use for the ethernet PHY device: Keil DP83848 ST STE100P Atmel DM9161AE IAR STE100P I think I will use STE100P, there seems to be more info and demo s/w for it.2011-05-17 12:36 AM
Hello!
I am using Davicom DM9161AEP with Taimag RJLBC-060TC magnetics - it works, it is RoHS and I can buy it from Dacom West GmbH.2011-05-17 12:36 AM
Quote:
I am using Davicom DM9161AEP with Taimag RJLBC-060TC magnetics - it works, it is RoHS and I can buy it from Dacom West GmbH. Are you using this chip in MII or RII mode ? I am not an ethernet expert, therefore I have to rely on ST example software, they use MII interface which requires many more pins to interface to STR91x [ This message was edited by: Arm_Wrestler on 13-02-2007 12:39 ]2011-05-17 12:36 AM
I am using MII. There are some special registers on the chip, but I guess it should work by using example from ST - but I don't try it.
