need a bidirectional level shifter
‎2007-05-04 8:09 PM
‎2011-05-17 12:42 AM
I want to use a STR912 in combination with TTL IC's. I need a bidirectional level shifter (3.3V <-> 5V) for my GPIO's. Any idea where I can find such a device. Luc Vercruysse- Mark as New
....I need a bidirectional level shifter (3.3V <-> 5V) for my GPIO's.
Any idea where I can find such a device... Why? STR91x's I/O is 5V tolerant (5.5V max), from datasheet first page: 5 V tolerant, 16 have high sink current (8 mA) and section: 6.4 DC electrical characteristics. In case I am missing something, check: ti.com
I agree, but I need a voltage shifter from 3.3V => 5V to drive my CMOS inputs...
Luc- Mark as New
I want to use a STR912 in combination with TTL IC's....
I need a voltage shifter from 3.3V => 5V to drive my CMOS inputs ...and now I am confused like a baby in a topless bar! :o
OK TTL is not correct.(English is not my native...)
I mean that I want to use the STR912 to access 5V devices (all technologies, 74LS, 74HCT, CMOS ...) I think CMOS is the worst case concerning input levels (input voltage seen as ''high'' is above 3.3V). For that reason I need voltage shift. Luc- Mark as New
look at 74LVC4245 :)
maybe 74LCX244 will help you
Unless the system is battery powered, pullup resistors should do the job as well.
...worst case concerning input levels (input voltage seen as ''high'' is above 3.3V)
True. You may want to look at this: > but, it looks like you got some hints what to use already....
