External Memory
jm
Posted on March 11, 2004 at 06:29
External Memory
4 REPLIES 4
jm
Posted on March 02, 2004 at 08:46
I work on ST10F168 and i use external ram by EBC in 16 bits demux mode.
There are 4 Chip Select available for ram : CS1,CS2,CS3,CS4
and 23 adress bits : A1->A23
So, there are (2^23 * 4) bytes accessible <=> 32Mo
I would to know if i am right and if i can declare an external memory map of 32 Mo !
Thanks for any suggestions !
Jim
charles239955_st
Posted on March 02, 2004 at 10:23
Hello Jim,
Unfortunatly the ST10 address range is limited to 16Mo (internal Flash included) because we only use 24 bit to create the total absolute address.
Bye
jm
Posted on March 08, 2004 at 09:35
Ok but 16*8bits or 16M*16bits ?
charles239955_st
16M*8bits
