COSMIC .bit section
irmakci2
Posted on April 25, 2006 at 08:58
COSMIC .bit section
irmakci2
Posted on April 21, 2006 at 12:54
Hi I want to use global bit and I read the document which was cross tutorial.We had had to declare .bit section in link file.But how to allocate to link file
example my link file is
+seg .text -b 0xfa00 -n .text # program start address
+seg .const -a .text # constants follow code
+seg .bsct -b 0x80 -m 0x80 # data start address
+seg .ubsct -n iram # uninitialized zero page
# define the .share segment when using compact or memory models only
+seg .share -a iram -n share -is # shared segment
Where and how should I allocate .bit section and which address if it is possible???Please help me?And Is ıt required identifier such as extern like global variables?
luca239955_st
see answer in the other post.
Luca
