2008-03-05 11:48 AM
Another I2C1 problem in NEW FWLib, see 91x_i2c.c
2011-05-17 02:32 AM
What about I2C1? see your own comments!
Doesn't any one Moderate this? I see no responses & I also sent this to Tech Support! /******************************************************************************* * Function Name : I2C_DeInit * Description : Deinitializes the I2C peripheral registers to their default * reset values. * Input :- I2Cx: I2C peripheral can be: * - I2C0 * - I2C1 * Output : None * Return : None *******************************************************************************/ void I2C_DeInit(I2C_TypeDef* I2Cx) { if (I2Cx == I2C0) { /* Reset the I2C0 registers values */ SCU_APBPeriphReset(__I2C0, ENABLE); SCU_APBPeriphReset(__I2C0, DISABLE); } }
