2003-11-05 03:15 AM
Will it work (SCI 1Mb Baud Rate)
2003-11-04 11:11 PM
I'm trying to get the Maximum Baud Rate possible from the SCI -
According to the Data Sheet its 500k. Look at my configuration and tell me if it's gooing to work - The configuration is for 1M Baud Rate with 16MHz CPU osc. SCIBRR = 0x00 SCIEPRP = 0x01 SCIETPR = 0x01 As you can see I'm using the extended mode of the SCI. What do you say ?2003-11-05 03:15 AM
