UART on ST7
bleumers_j
Posted on April 26, 2004 at 11:11
UART on ST7
8 REPLIES 8
bleumers_j
Posted on April 22, 2004 at 05:37
Hi
I wrote software for an ST7LITE29 that converts DMX to 3 PWM outputs.
DMX is a asyncronous protocol at 250kHz and 9 bits per frame.
Since st7lite29 has got no uart, i wrote a software uast myself. It worked fine for a long time.
Now a protoserie is made, the software fails sometimes (small diffrence in resonator frequency...)
I'd like to change to an ST7 with an UART, so i can use the same software without the ''selfmade uart''
Any ideas
bleumers_j
Posted on April 22, 2004 at 06:19
I removed a 'nop' instruction and the thing works again!
Maybe the code was changed by accident???
But now i'm doubting, is this a good way to word, should it be better to use a controller with a real uart???
sjo
Posted on April 22, 2004 at 06:39
DMX512 as you said is a serial protocol - simply RS485 at 250kbaud.
That s quite a speed to handle in software, I think a better micro would be the ST72F264 which has a hardware uart.
sjo
jatin
Posted on April 22, 2004 at 07:22
There is an application note available on this site for yor application i.e. AN1753 ''Software UART using ST7 12-Bit Autoreload Timer''.
bleumers_j
Posted on April 22, 2004 at 07:49
Thanks for your fast responses.
The AN1753 -uart works up to 19200 Baud and DMX = 250000 Baud.
When i look at the datasheet of the ST72264G (i think this is the same as the ST72F264, you mentioned) i do not see an uart. In fact i do not find any st7 with an uart.
Greets
sjo
Posted on April 22, 2004 at 08:49
ST call it an SCI
sjo
bleumers_j
Posted on April 26, 2004 at 10:30
Thanks for your help!
I have asked some samples of an ST7 with SCI.
But still one thing isn't clear yet:
To decode DMX the number of frames after the break should be counted. So this counter has te be resetted at each break.
How can i know when a break occurs? A break is handled as a framing error and a FE generates no interrupt. So, is the only way polling all the time the FE-bit and checking the SCIDR for value 0?
Thanks!
sjo
A receive interrupt will be generated (RDRF), you can check for framing error in this interrupt. FE and RDRF bits will be set together.
sjo
