2007-08-08 08:59 PM
2007-08-08 04:25 PM
As far as I have examined datasheet, STR710 UART does not seem to support 7 data bits with no parity.
I might need this feature and I wonder I am right. Please inform me if this UART mode is possible or not. Thanks.2007-08-08 08:59 PM
According to the datasheet, there is no option to have 7 data bits with no parity bit.
As a workaround, if you can do with more than 1 stop bit, you can consider the 8th data bit in the frame as 1 stop bit.
