St72F324 RTC timebase error
akel
Posted on April 03, 2006 at 14:49
2 REPLIES 2
akel
Posted on April 03, 2006 at 13:35
Hi Users,
I use RTC timebase timer interrupt for many events
and i have 2 problems. I set MCCSR=0x02;
so I should have interrupt every 2ms by 8MHz clock,
but i have every 4ms ( in option HS:8-16MHz range and resonator type
- real I have 8MHz resonator)
Next problem is that sometimes I have interrupt one after one
- looks like not interrupt flag cleaning, but on the beginning
of interrupt routine I clear MCCSR&=0xFE flag OIF.
I use Cosmic C compiler.
Thanks for any help
Andrew
Viktor POHORELY
Concerning frequency, look into chapter 10 - Fosc2 means half of the Focs, e.g. crystal frequency.
try to go to disassembly to see, what is listing of your C code. To clear OIF, it should be enough to write
MCCSR; // clear OIF flag
in your C code. Flag is cleared by read access to MCCSR and Cosmis will handle it properly.
Setler
