Output compare function
jackie2
Posted on April 03, 2006 at 15:25
jackie2
Posted on March 27, 2006 at 09:17
In the data sheet of ST7: to reset the OCFi flag, two step are required:
1. Reading the SR register while the OCFi bit is set.
2. An access(read or write) to the OCiLR register.
What is the definition of ''access'' to the OCiLR register? If the code as follows:
LD A, #$20
ADD A, OCiLR
stands for ''an access'' to the OCiLR?
or If the code as follows:
LD A, OCiLR
ADD A, #$20
tks!
Viktor POHORELY
both of them. but you can try it easily... ;)
