2003-10-30 01:34 PM
2003-10-22 03:49 AM
Is it possible with the ST72F324 device to execute code in RAM between 100hex and 130hex assuming the Stack is empty i.e. pointing at 1FFhex.
2003-10-22 09:44 PM
If you keep an check on your stack usage this is ok.
Be careful if you are doing IAP as the stack (124 bytes) is required by the embedded commands. Regards sjo2003-10-30 01:34 PM
Check the Application note i have attached.
Hope it can help. ________________ Attachments : ram_execut.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I09e&d=%2Fa%2F0X0000000bUS%2FU4wVgJeopsB8gFtySKTCjxxJlRd2dhUg3ns9QsJp51Y&asPdf=false
