2006-04-24 09:27 PM
2006-04-24 09:27 PM
Hi.
I have a ST7 and ST7538 system setup. The ST7538 is setup to default and the data is distributed through the sci on the ST7. I have seen sometimes, that some of the variables I distribute from one system to another is wrong, even if I do a simple checksum on it. Can I experience some sort of noise that makes the checksum right but makes the variable value wrong? Could I benefit from using a CRC-8 or CRC-16 checksum calculation to make sure that this is not the problem? Regards and thanks. Peter
