2003-03-18 08:40 PM
2003-03-18 08:24 PM
Hello
I have a customer that is interested to know more about the reseved memory area in the ST72C334N2/N4 microcontroller . He need this information because he is devoloping an application that require safety information . Just to clarify I'll give you a question list that come from my customer : 1) What is written in Reserved area , because if the program counter go inside this area I need to know what can happen . 2) Is It possibile to fill this area with all FFH or 00 to avoid any kind of impredictable situation if the program counter go inside it . 3) I had experience with ST6 (ST62T32) and with this microcontroller was possible to fill the reserved area . It is very important to know this information , otherwise the customer will choose other microcontroller from other supplier . Please help me Thanks Vikingo2003-03-18 08:40 PM
As far as I'm aware, the reserved area contains nothing and test code. The ST7 can address the whole 64k memory area, the PC can contain any value from 0 - 65535. You can try to execute anywhere ! As some of the area has nothing, it can not be loaded with a value. There is no way to guarantee the software operation in these conditions. You have the watchdog if it jumps into nowhere and gets stuck there. Simon [ This message was edited by: sjh on 12-11-2003 16:21 ]
