redeclared error
wileti
Posted on September 11, 2007 at 06:02
redeclared error
2 REPLIES 2
wileti
Posted on September 10, 2007 at 17:02
Hi all,
I´m using ST72F63B microcontroller and after compilation the below messages are prompted:
#error cpst7 io72263.h:7(14+4) redeclared localized PADR
#error cpst7 io72263.h:9(14+5) redeclared localized PADDR
#error cpst7 io72263.h:11(14+4) redeclared localized PBDR
#error cpst7 io72263.h:13(14+5) redeclared localized PBDDR
and so on...
In actual fact, I´ve declared these variables once a time in io72263.h file as described below:
volatile char PADR @0x00; /* Port A Data Register */
volatile char PADDR @0x01; /* Port A Data Direction */
volatile char PBDR @0x02; /* Port B Data Register */
volatile char PBDDR @0x03; /* Port B Data Direction */
volatile char PCDR @0x04; /* Port C Data Register */
volatile char PCDDR @0x05; /* Port C Data Direction */
volatile char PDDR @0x06; /* Port D Data Register */
volatile char PDDDR @0x07; /* Port D Data Direction */
and so on...
Thus, I have no idea for these error messages. Where should I try harder in order to find out the problem?
Thank you for any help,
Wilson
luca239955_st
the message is quite clear: you declared every var more than once.
Maybe you include the same file twice, or you include a file with the declarations in a file where the vars are already declared: it should be easy to find out.
