2009-06-09 02:19 PM
2009-02-09 03:51 AM
Sirs, I need you help.
For long time I’m having randomize problems with my STR711 and IAR EWARM 4.41. They are related to SPRINTF(). Usually it worsk fine but when I modify some part of code, then another part code containing a SPRINTF() fails. Does anybody had or have problems with this function? Any advice? I'm thinking to do my own source code for this function :( Really desperate issue. Thanks ALFA. [ This message was edited by: amoreno on 09-02-2009 18:03 ]2009-02-10 12:07 AM
This could be caused by stack overflow.
2009-04-09 03:18 AM
Hi, did you solve the sprintf problem ? I am having same problem with ARM9, an I don't think is a stack overflow problem
Regards, paolo2009-06-09 02:19 PM
Did you solve the problem with sprintf ?
I'm having an odd result using the %f to convert a float value. But it works fine with decimal values: sprintf(buffer,''Number: %d'',anInteger); <--- Works fine. sprintf(buffer,''Decimal: %f'',aFloat); <--- a 0.0 is returned Mark
