2007-05-02 08:17 PM
2011-05-17 12:42 AM
This is simple project writen in KEIL and based on KEIL FMI_library.
Please somebody check what is wrong? I use led blink functions for test purpouses but it is possible to test just in debuger. Note: Change configuration files and the STR91xD.LIB path if needed. And answer me please if you will find bugs in code. Also note me if all OK (Simply if the writen to flash value is equal to read from flash value) Thank you veryyyyyy muuuuuuuuuuuuuchchchchchchch!!!!!!!!!!!!!!!!!!!!!!!!
