2006-04-03 11:10 AM
How to add real date to compilation (Cosmic)
2006-04-03 04:49 AM
It is possible to get by compiler real date from computer RTC and put to defined place in Flash memory. I want to use it as version identifiction Regards Andrew2006-04-03 06:21 AM
I dont think it is possible, but there is no reason to do that, isn't it better to put your own version number into FLASH and increase it in case you have made some changes into the source code?
2006-04-03 11:10 AM
