Could help me identify this HDD (Hard Drive PCB) TVS diode part? SUG SUA
Ayoob
Hi ,
Could help me to identify the model of this TVs diode
it’s from WD external 4TB HDD
Thanks in advance.
7 REPLIES 7
"the marking is SUA, which corresponds to the SMA6F5.0A-TR, which can be found today with 6AI marking."
https://community.st.com/t5/other-hardware/hi-could-you-please-help-me-identify-this-diode/td-p/197883
Thanks for reply ,
What about the first TVs Diode which stands with SUG marking ?
"SUG stands for the SMA6F13A-TR"
https://community.st.com/t5/power-management/unable-to-find-diode-or-cross-ref/td-p/683783
BarryWhit
Lead II
@Lina_DABASINSKAITE , here's another example of missing labels. The forum sees a slow but steady stream of such chip identification help requests, but there's no forum label for it. In lieu of a dedicated subforum, a dedicated label would be nice.
- If someone's post helped resolve your issue, please thank them by clicking "Accept as Solution".
- Please post an update with details once you've solved your issue. Your experience may help others.
@BarryWhit There is a label: Power Managment > Discretes
Well, maybe not the ideal combination, but should mostly work - doesn’t it?
/Peter
As it is it shows up in my feed, I'm Ok with it, and the more times we answer the better the chance of a direct Google Hit for the self-service customers
These particular diodes being a pain due to lack of marking documentation, and the markings changing from current issue parts.
ST STMICRO DIODE SUA SUG MARK MARKING
HARD DRIVE DIODES
600W TVS
OLD: SUA SMA6F5.0A NEW: 6AI
OLD: SUG SMA6F13A NEW: 6AY
Yes, this may be a little confusing, but all SMA6F (package SMA Flat) are obsolete and no longer visible on the ST website, please do not confuse it with SMA6J (package SMA).
