2008-01-09 12:12 AM
Can USB_clk pin of STR9 used as GPIO even USB function enable?
2011-05-17 12:49 AM
and the USB 48MHz is from internal clock!2011-05-17 12:49 AM
Hi Kuni,
Yes, you can 😉 Looking on Table 5 (Device Pin Description) in the STR91xFA datasheet : the default Input/output function of Pin 2.7 is standard GPIO. Hope this clarifies. STOne-32 🙂 [ This message was edited by: STOne-32 on 09-01-2008 13:43 ]
