CAN bus
craig239955_st
Posted on June 05, 2007 at 11:11
CAN bus
3 REPLIES 3
craig239955_st
Posted on May 17, 2011 at 09:44
Hi all,
I have an application where a STR912 communicates with a PIC controller using CAN bus.
The STR912 sends data to the PIC controller.
when I configure the STR CAN device in testmode with loopback enabled (not silent), It works fine.
On my oscilloscope, I see a valid CAN message and my PIC receives this message correct.
However, when I disable the loopback, on the oscilloscope I see a train of pulses for 1 second and the pic does not receive any valid message. I use the STR912 library.
I think it has something to do with bus-arbitration, but the function CAN_sendMessage() does not return an ERROR condition.
Can somebody help me please.
Luc vercruysse.
heiko2399
Try changing the bit timing
In 91x_can.c if have changed the line:
CAN_TIMING(11, 4, 4, 4), /*0x3AC3 125 kbit/s 16 11 4 4 4 */
to:
CAN_TIMING(13, 5, 4, 40), /*0x3AC3 125 kbit/s 16 11 4 4 4 */
I am using ST library and and 96MHz PCLK.
The timing is not perfect but works for my first test.
craig239955_st
Thank you for response. I did already change the baudrate settings to the correct settings.
There were 2 problems, one problem on the PIC-side.
After solving this problem it still didn't work.
As I sead in an earlier thread
http://mcu.st.com/mcu/
there are problems using UARTs on port3 in combination with CAN on port 5.
I found out that when defining the Txd pins (as output)on port 3, you have to disconnect them from input function using GPIOInit.GPIO_IPConnected = GPIO_IPConnected_Disable.
I think I have to start a new thread with this bug, somewhere on this forum somebody has the same problem.
Luc
