2006-05-29 03:32 AM
2006-05-08 03:55 AM
Is there any cross-compiler available, which supports C++ for ST7? Is there any RTOS support available for ST7? Regards, Yogesh & Amit2006-05-25 01:44 PM
i also want ask such a question.i
2006-05-29 03:32 AM
For the C++ C compiler, even if you find one I do not see any benefit from using C++ on an MCU such as the ST7.
For the RTOS I would recomend µC-OSII which is quite cheap (you just have tu buy the book with the sources) and there has been a port to ST72 eventhough it is not on the Micrium web page dedicated to ST ( ) .
