2018-11-01 02:51 AM
currently, lis3dh is running well with IA1 function, but if i want to change some config,
such as CTRL_REG1(20h) for change target axis
INT1_CFG(30h) for target axis and direction change
INT1_THS(32h) for threashold change
what is the correct procedure for config's change ?
regards
Gary
2018-11-02 02:31 AM
Basically you can change any register any time, but I would switch the sensor to power-down mode (CTRL_REG1 = 0x0?), then modify the configuration and then switch on again.
2018-11-04 12:39 AM
thanks, it works to me,
regards
Gary
