What in-circuit debugger/programmer should I use for STEVAL-MKSBOX1V1?
Eugene Agustin
I am using STEVAL-MKSBOX1V1 and I want to do some changes in the firmware.
What in-circuit debugger/programmer should I use? Should I use ST-LINK/V2 or STLINK-V3SET or STLINK-V3MINI?
Please help me. Thank you
Eleon BORLINI
Hi @Eugene Agustin​ , if programming through JTAG/serial wire debugging (SWD), I suggest you to use the ST-LINK/V2 programmer because of 1.8V level compatibility with ,ow power STM32L4R9. The HW connection is the connector numbered "8". Board schematic will be available soon on st.com. Regards
27 REPLIES 27
Manual says "The board includes the ST-LINK V3 (with UART pins for debugging) compatibility."
Unfortunately no pictures of the back side of the board.
Suggest you contact your local sales office and discuss.
Eugene Agustin
Here is the back side of the board.
Please look at the attached image thank you
No picture attached. Make sure you upload and insert it.
Eugene Agustin
Sorry I forgot to insert.
Thank you
Eleon BORLINI
Hi @Eleon BORLINI​ ,
I already bought an ST-LINK/V3 since it is the newer version. Am I right that it will work on SensorTile.box for programming?
Thank you
DIM
Hi @Eugene Agustin​ did you find an answer to your question?
I know the STLINK-V3SET is compatible with the MKSBOX1V1 as per this post.
This document compares STLINK-V3SET and STLINK-V3MINI on Page 2.
Hi @DIM​
Not yet.
Thank you for sharing the information. I need some quick start guide or manual on how to use STLINK-V3SET on MKSBOX1V1.
