What in-circuit debugger/programmer should I use for STEVAL-MKSBOX1V1?
‎2019-07-08 7:22 PM
I am using STEVAL-MKSBOX1V1 and I want to do some changes in the firmware.
What in-circuit debugger/programmer should I use? Should I use ST-LINK/V2 or STLINK-V3SET or STLINK-V3MINI?
Please help me. Thank you
ST-Link
‎2019-07-15 1:32 AM
Hi @Eugene Agustin​ , if programming through JTAG/serial wire debugging (SWD), I suggest you to use the ST-LINK/V2 programmer because of 1.8V level compatibility with ,ow power STM32L4R9. The HW connection is the connector numbered "8". Board schematic will be available soon on st.com. Regards
‎2019-07-08 7:56 PM
Manual says "The board includes the ST-LINK V3 (with UART pins for debugging) compatibility."
Unfortunately no pictures of the back side of the board.
Suggest you contact your local sales office and discuss.
‎2019-07-08 8:45 PM
Here is the back side of the board.
Please look at the attached image thank you
‎2019-07-11 12:28 AM
No picture attached. Make sure you upload and insert it.
‎2019-07-11 5:49 PM
‎2019-07-11 5:50 PM
Sorry I forgot to insert.
Thank you
‎2019-07-15 1:32 AM
‎2019-07-15 5:38 PM
Hi @Eleon BORLINI​ ,
I already bought an ST-LINK/V3 since it is the newer version. Am I right that it will work on SensorTile.box for programming?
Thank you
‎2019-07-21 7:09 PM
Hi @Eugene Agustin​ did you find an answer to your question?
I know the STLINK-V3SET is compatible with the MKSBOX1V1 as per this post.
This document compares STLINK-V3SET and STLINK-V3MINI on Page 2.
‎2019-07-22 7:04 PM
Hi @DIM​
Not yet.
Thank you for sharing the information. I need some quick start guide or manual on how to use STLINK-V3SET on MKSBOX1V1.
