Use LSM6DSO to detect free-fall event can not work!
Ljian.1
According to the official sample program, I set the register to detect free-fall event,But it can't be detected very well, even when I haven't moved anything, I have always detected the free-fall event,How can I use lsm6dso to detect free-fall event correctly?
4 REPLIES 4
Ljian.1
This is the official sample program I refer to
Eleon BORLINI
Hi @Ljian.1​ , on which part number did you managed to detect the free-fall event, before LSM6DSO? You could try to change the detection threshold to a lower value and check if you can detect the free-fall interrupt.
  /* Set Free Fall duration to 3 and 6 samples event duration */
  lsm6dso_ff_dur_set(&dev_ctx, 0x06);
  lsm6dso_ff_threshold_set(&dev_ctx, LSM6DSO_FF_TSH_312mg);
Ljian.1
This is the first time I have used lsm6dso to detect free-fall events. I have not used other ones before.
I changed the detection threshold to a lower value still not work!
Ljian.1
This is my enable free-fall detection sourcecode.
void static FallDetectionInit(void)
  //stmdev_ctx_t dev_ctx;
  lsm6dso_pin_int1_route_t int1_route;
  * Uncomment to configure INT 2
  //lsm6dso_pin_int2_route_t int2_route;
  * Initialize mems driver interface
  //dev_ctx.write_reg = platform_write;
  //dev_ctx.read_reg = platform_read;
  /*--------Enable free-fall detection from sensor(lsm6dso)--------*/
  /* Enable LIR */
  lsm6dso_int_notification_set(&dev_ctx, LSM6DSO_ALL_INT_LATCHED);
  lsm6dso_ff_dur_set(&dev_ctx, 0x03);
  /*--------Enable detect activity/inactivity from sensor(lsm6dso)--------*/
  /* Set duration for Activity detection to 9.6 ms (= 4 * 1 / ODR_XL) */
  lsm6dso_wkup_dur_set(&dev_ctx, 0x04);
  /* Set duration for Inactivity detection to 4.92 s (= 4 * 512 / ODR_XL) */
  lsm6dso_act_sleep_dur_set(&dev_ctx, 0x04);
  /* Set Activity/Inactivity threshold to 62.5 mg */
  lsm6dso_wkup_threshold_set(&dev_ctx, 0x02);
  * Inactivity configuration: XL to 12.5 in LP, gyro to Power-Down
  lsm6dso_act_mode_set(&dev_ctx, LSM6DSO_XL_12Hz5_GY_PD);
  * Enable interrupt generation on Inactivity INT1 pin
  lsm6dso_pin_int1_route_get(&dev_ctx, &int1_route);
  int1_route.md1_cfg.int1_ff = PROPERTY_ENABLE;
  lsm6dso_pin_int1_route_set(&dev_ctx, &int1_route);
  /* initialize variables */
  fall_occur = FALL_DETECT_FALSE;
  fall_detect_status = FALL_DETECT_STATUS_NONE;
  return;
