Strange behavior with call to HAL_GPIO_ReadPin()
jgauthier
Senior
I am seeing some strange happenings using X-CUBE-MEMS software pack, which generates some code for user buttons, LED outputs, etc.
I noticed the user button was always returning GPIO_PIN_SET even when it should be returning GPIO_PIN_RESET
I make a call like so:
PushButtonState = BSP_PB_GetState(BUTTON_KEY);
Which calls this function: (I've added some serial debug output)
int32_t BSP_PB_GetState(Button_TypeDef Button)
	GPIO_PinState bitstatus;
  bitstatus =  (int32_t)(HAL_GPIO_ReadPin(BUTTON_PORT[Button], BUTTON_PIN[Button]) == GPIO_PIN_RESET);
	serprintf("After call: %i\n", bitstatus);
	return bitstatus;
Which calls this function (again with debug output added)
GPIO_PinState HAL_GPIO_ReadPin(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
  /* Check the parameters */
  assert_param(IS_GPIO_PIN(GPIO_Pin));
  if ((GPIOx->IDR & GPIO_Pin) != 0x00u)
    bitstatus = GPIO_PIN_SET;
  else
    bitstatus = GPIO_PIN_RESET;
	serprintf("Bitstatus: %i\n", bitstatus);
  return bitstatus;
HAL_GPIO_ReadPin is returning GPIO_PIN_RESET as expected, but the calling function doesn't seem to know that. My serial output looks like this:
Bitstatus: 0
After call: 1
What is happening here?
2 REPLIES 2
If HAL_GPIO_ReadPin returns GPIO_PIN_RESET (0), then this comparison evaluates true which returns 1.
In other words, the return value from BSP_PB_GetState is opposite of the return value from HAL_GPIO_ReadPin.
Edit:
A search on GitHub shows your implementation is the opposite of what is there, at least on this instance:
https://github.com/rajeev1986/ST25dv-sdk/blob/b0ff4ffadc361684b8c35aaddb3f2f340f0052df/Drivers/BSP/ST25-Discovery/st25dx_discovery.c#L362
jgauthier
Senior
Ah! I totally missed the comparison. Thanks for pointing that out.
