2020-07-30 05:47 AM
Hi, im have:
https://www.st.com/en/evaluation-tools/steval-mki181v1.html
I have connected after i2c in esp32. It works and sometimes disconnects it. Do you need to use any resistors?
2020-07-30 08:03 AM
Hi @Bacteriusartnik , yes, pull-up resistors are warmly suggested on the SDA and SCL I2C lines. 5k or 10k are ok. Regards
2020-07-30 08:03 AM
