steval-mki181v1 - i2c connected problem...
Options
‎2020-07-30 5:47 AM
Hi, im have:
https://www.st.com/en/evaluation-tools/steval-mki181v1.html
I have connected after i2c in esp32. It works and sometimes disconnects it. Do you need to use any resistors?
Options
‎2020-07-30 8:03 AM
Hi @Bacteriusartnik​ , yes, pull-up resistors are warmly suggested on the SDA and SCL I2C lines. 5k or 10k are ok. Regards
1 REPLY 1
Options
‎2020-07-30 8:03 AM
