2024-03-11 04:24 AM
From the following repo https://github.com/STMicroelectronics/st-mems-android-linux-sensors-hal/tree/master
I would like to know if the driver it's compatible with an Android environment under snapdragon where all the sensors part is managed under the ADSP and the SSC core library. On this systems the sensors part is managed trough the SSC Framework who handles the sensor core functions.
Does anyone have experience with it or know if it is compatible?
Thank you.
2024-03-12 05:51 AM
Hi @DevM ,
Unfortunately, it is not compatible.
2024-03-12 05:51 AM
Hi @DevM ,
2024-03-12 06:13 AM
Thanks @Federica Bossi
