Is VL53L1X people counting source code available?
‎2018-12-17 3:19 AM
I saw the VL53L1X used as a people counter video at:
https://www.youtube.com/watch?v=c91Ve-g0J2U
Is the source code used in that video available?
TIA,
- Labels:
Time of flight
‎2019-02-01 8:20 AM
I join to question.
‎2019-02-03 8:53 PM
What is the idea behind people counting using VL53L1X sensor Since this sensor is used for measuring the distance. How to detect whether the obstacle is people or not?
‎2019-02-03 10:38 PM
I guess they use more than one ROI SPAD regions, but it is beyond current API
‎2019-02-04 10:08 PM
I did it! It is very simple.
Unlike ST I will not keep mysterious silence and will publish the code after some tests.
‎2019-02-05 4:27 AM
This example illustrates direction recognition with the single VL53L1X TOF sensor. Two Regions Of Interest(ROI) are defined in SPAD sensor array:
ROI1 ROI2
0,15___12,15
_____3,0 _____15,0
Data measurements distance0 and distance1 cyclically readed from both ROIs, switching them on the fly.
Then STM32duino_Proximity_Gesture library used for event interpretation.
To suit Arduino requirement I added necessary library description to Pololu vl53l1_api.
Also, to handle handMustCoverBoth parameter support in STM32duino_Proximity_Gesture library, I had to slightly modify tof_gestures_DIRSWIPE_1.cpp and tof_gestures_DIRSWIPE_1.h. Both libraries are included in this bundle.
This code is for WEMOS D1 mini Lite, but with board and pins adjustments will work with any Arduino.
Data outputs to serial @115200 and to OLED. For investigations and adjustments it is suitable to use SerialPlot: https://bitbucket.org/hyOzd/serialplot.
Files here:
https://yadi.sk/d/UIIAXFol3P_jXg
Video here:
‎2019-02-05 8:04 PM
Thanks for sharing your source code. I am using Nucleo - F401RE board with VL53L1X sensor. Is it possible to use this code in stm nucleo board?
‎2019-02-05 10:49 PM
Sure.
You can adapt SimpleRanging example code (from STM32CubeExpansion_53L1A1_V2.0.1) to suit the task.
‎2019-02-06 1:26 AM
What changes has to be done in the simple ranging code for counting the number of people? I have already changed the ROI of the sensor. Now how to detect people using this sensor?
‎2019-02-06 1:45 AM
Are you completely novice in this field?
Counting code lays between 134-148 lines of my example.
