2020-01-03 03:23 PM
2020-01-13 11:41 PM
Hi @STeag.1 , there isn't a standard "connection" between the pressure port and a pressure tubing, let me say something like a standard pressure fitting. However, hardware guidelines are available for LPS22HB/LPS25HB pressure sensors system integration that can be used also for the LPS35HW. To have something closer to a more standard fitting you could use the LPS33HW, which has a bigger pressure port and is itself water resistant. Regards
